Home Forums Products Stompboxes H9 Program Change Messages Reply To: H9 Program Change Messages
#137106
jhyman
    From the H9 Owner's Manual:
     [XMT.MAP] – Create a MIDI Program Change Transmit Map
    When the Left Footswitch loads a Preset, a MIDI Program Change message can be
    transmitted from the MIDI Out jack or USB to control an external device – e.g.,
    another Eventide Stompbox, an Eventide Eclipse, an Eventide H8000FW, etc.
    [PGM.XMT] – MIDI Program Change Transmit Enable (ON, OFF)
    Press the HOTKNOB button to select. Turn the Knob to set MIDI Program Change
    transmit ON or OFF. If ON, a MIDI Program change message is transmitted
    whenever a Footswitch is pressed for Preset load.
