Home Forums Products Stompboxes V5 Beta for TimeFactor! Reply To: V5 Beta for TimeFactor!
#137127
gkellum
    almesy:
    So i can do it now, even without owning the H9, and use later?  The instructions seemed to imply you had to have both the TF and the H9 at the same time.
    Yes, you can update now without an H9 and use the coupons later. The instructions were saying that to USE the coupons you have to have both the TF and the H9 connected to H9 Control at the same time. The way the process works is that when you connect your TimeFactor to H9 Control the first time and verify your registration of your TimeFactor it creates an entry on our server for your TimeFactor with your two coupons. Those coupon entries stay there until they're used even if you don't have an H9 and even if you sell your TimeFactor to someone else.
