Home › Forums › Products › Stompboxes › Space glitching out and running through menu’s › Reply To: Space glitching out and running through menu’s
August 25, 2014 at 8:24 pm
#137236
This is probably a bad internal connection, most likely in the ribbon cable that goes between the two circuit boards. You could try and fix it yourself, otherwise it has to come in.
