Home Forums Products Stompboxes Problem with ultra tap Reply To: Problem with ultra tap
#137246
wedelich
    The input signal to the H9 is the only one that matters in triggering the Swell, it should be fine for your amp to be at a low volume.  What type of guitar/input are you using?  You might also want to try adjusting the input sensitivity of the H9 higher for quieter guitars like Telecasters.
