Home › Forums › Products › Stompboxes › Space algo question › Reply To: Space algo question
#137278
Cool, just to clarify (hard to conceptualize without the hardware in front of me):
"Toggling between two  presets in a single preset" confuses me a bit – does that mean two reverb presets in a single algorithm, or just change a parameter in a preset. Can I go from a long hall reverb to a short spring or room?
Toggling the repeat, just means turning on and off the repeats? Is that pretty much the same as turning off the delay ? Seems no repeats = no delay, so just like hitting the bypass or off button on the pedal?
Also, do they make a switch that has three buttons plus an expression pedal? Or would the expression pedal have to be midi?
