Home Forums Products Stompboxes Timefactor and Space on Mesa Dual Rectifier Loop FX Reply To: Timefactor and Space on Mesa Dual Rectifier Loop FX
#137342
MarcoR
    That mixer may work for you
    and the features look cool for an all in one solution. I just don't know how
    transparent it will be as I’ve never tried it. Running the effects in parallel
    sounds great but you have to consider if you want to feed one effect into
    another for certain combinations.
    Also, because the infamous Mesa loop will
    bleed some dry signal back and cause phasing issues, you may not have any luck
    with serial routing and running everything parallel may be the only option (with
    killdry enabled on all processors).
    The problem with that is that if you are
    using a whammy effect for example, you would not be able to apply reverb and
    delay to the pitch altered signal. I would find someone that can do the effect
    loop mod on the Mesa and still use a splitter/ mixer configuration.
