Home Forums Products Stompboxes Pitch Factor glitches after software update Reply To: Pitch Factor glitches after software update
#137369
    You can back up the presets to a PC over USB using the MIDI dump, but this requires a sequencer or similar software on the PC and knowing how to use it. No MIDI cable would be needed.
    If you can handle the above,  the MIDI dump command on the PF will be a piece of cake.
