Home › Forums › Products › Stompboxes › H9 Wish List › Reply To: H9 Wish List
October 18, 2014 at 11:19 pm
#137478
hendrik7:
When I'm editing a preset on the fly with XYZ buttons I would like to see the parameters number. The red circle doesn't help much. If I'm editing the Mix I would like to see the number (1-100) – if I editing the Decay I would like to see the seconds(like when editing ModEchoVerb presets) etc.
You can do that now by switching into Expert mode. If you long press a switch, the parameter assigned to that switch will show its values… Each switch must individually be put into Expert mode…
