Home Forums Products Stompboxes H9 MIDI controller DIY Reply To: H9 MIDI controller DIY
#137487
marcusm750
    Bonjour Poppy,
    Excellent work once again on this H9 controller.  Tres bien!
    I've been following your updates on the Sweepyo Web site and was wondering how the capacitor bypassing on the potentiometers is working out to tame their jumpiness.  Was there any capacitance added to the sweep (middle) terminal to ground or just between the power and ground connections to the pots (outside terminals)?  Does the cap bypassing seem to be working for the footswitches as well?
    Also, you stated in the update that you changed the code to make the pot inputs more sensitive but shouldn't it be the other way to make them less sensitive and thus less jumpy?  Or was this to have the complete rotation of the pots fully expressed in the broadcasted MIDI values?
    Merci beaucoup a l'avance pour votre commentaries.
    Cheers,
    Mark
