Reply To: Space–can’t get expression pedal to work
Home Forums Products Stompboxes Space–can’t get expression pedal to work Reply To: Space–can’t get expression pedal to work
#137514
gkellum
It doesn't require Bluetooth. You can hook up an H9 to it via Bluetooth, but you can hook a Space up to it with USB. You should just need to connect your Space to your computer with USB and launch the app and it will find it as described in the manual:
http://eventide.com/AudioDivision/Products/StompBoxes/H9ControlUG1.aspx
