Home › Forums › Products › Stompboxes › Moog MP-201 as controller for 3 Factor pedals, has anyone done this yet? › Reply To: Moog MP-201 as controller for 3 Factor pedals, has anyone done this yet?
imerkat:
Hello, I've own the Moog Multi-pedal and been using it with Eventide stuff since forever. not sure, what type of advice do you need? both the Eventide and the MP-201 are so flexible you can accomplish just about anything in terms of Midi control. I do think the MP-201 is suited best for analog gear with CV and Synths with MIDI-note capability.
Hi imerkat,
Would you know how to adjust the MP-201 CV to 0-3 instead of 0- 5?
When using LFO modulation, the parameter modulated – from 0 to 100 in the H-9 – by the Moog pedal "stucks" at 100 for some time and then goes down and up smoothly till it reaches the top again. I guess that may be caused by the H-9 freezing at max (100) when the CV reaches 3 v and all the way up to 5 v and down from 5 v to 3 v again.
Is there a way to implement that using the midi output of the MP-201?
Thank you very much!
