Home Forums Products Stompboxes Looper dub quantize Reply To: Looper dub quantize
#137705
wedelich
    bodde:
    You can not immediate record a new fresh loop like you can with the Hexe.
    I have to point out that while the H9 button interface is admittedly limited (only 2 buttons), the H9 Looper is essentially the Timefactor Looper under the hood.  Thus, it does allow you to record a new loop at any time, even when not empty.  This functionality can easily be utilized on H9 via the H9 Control Record button, or an Aux Switch /  MIDI CC assigned to REC.
