Home › Forums › Products › Stompboxes › Max out upgrade: how to tell how many algorithms you’ve purchased already? › Reply To: Max out upgrade: how to tell how many algorithms you’ve purchased already?
purpletiger:
Hi gkellum,
I want to make sure I understand all of this.I have a H9 and a H9 Core.
I have a total of 19 algorithms including the recent release of looper. If Iam calculating correctly that means I need 4 more to upgrade
- 19 – Loooper = 18
- 18 – 2 free coupons (one from H9 and one from H9 Core) = 16
- 16 – 10 (algorithms that came with H9) = 6
- 6 + 4 = 10 (The algorithms upgrade from H9 is 10)
Is this correct.
Also would both of my H9's then be H9 MAX''s?
I looked up your account and I see 18 algorithms in your account (not 19) and that you've purchased five algorithms. In your case it's 18 minus the 9 that come bundled with a standard minus the two coupon purchases and minus Looper and Resonator which were free which leaves five algorithms which you purchased. That means you have five more to go.
After you purchase those five your H9 Standard would be converted to an H9 Max, and you could use all of the algorithms on your H9 Core as long as you still own the H9 Max but it will remain an H9 Core.
