Home › Forums › Products › Stompboxes › H9: using US power supply in Europe › Reply To: H9: using US power supply in Europe
#137815
gkellum
    The Eventide power supply is a switching power supply which can work either when supplied with 110V or 230V. It should say that on the label of the power supply. So, yes, (b) you can use an adapter.
    Incidentally, if you're under powering your stompbox, you may run into trouble saving settings and presets as well.
