Home Forums Products Stompboxes MaxOut Upgrade: Upgrade only available to a single device? Reply To: MaxOut Upgrade: Upgrade only available to a single device?
#137842
gkellum
    dafonk:
    Is it possible to have access to all the Algorithm from the H9 core alone without the H9 control if you have an H9 max ?
    If yes, how to load the algorithm into the H9 core ?
    I don't understand the question. Are you asking can you install all of the algorithms onto an H9 Core if you have a Max without using H9 Control? No, you need to use H9 Control to install the algorithms on the H9 Core. Or are you asking can you change the active algorithm on your H9 Core without using H9 Control? Yes, if you press the Preset switch twice, it switches from changing presets to changing algorithms.
