Home › Forums › Products › Stompboxes › H9 as a volume pedal? › Reply To: H9 as a volume pedal?
January 8, 2015 at 4:48 am
#137940
Yes. Why waste a H9 for a volume swell when you can just connect it passive before delays anyway?
The only reason I can see you would do this is if you have multiple H9's, plenty of of cash to max them out….. or you use the EXP primarliy for other effects.
I have thought about building a switching router to switch between passive volume or EXP but I think I would rather just use it as a passive volume.
