Home › Forums › Products › Rackmount › H8000FW AES/EBU clocking issues › Reply To: H8000FW AES/EBU clocking issues
#138045
    You could certainly use S/PDIF (the one by the Wordclock connector).
    A mixed setup is fine, but you should avoid having the sync signal pass through pieces of equipment – it is best if it fans out from a single point.
    For a complex system W/C is often preferrred, because you can easily daisy-chain the sync connections (as long as you understand termination), and it may have lower jitter which can cause a slight but probably imperceptible distortion reduction.
