Home › Forums › Products › Stompboxes › New TimeFactor V5.0.0beta[75] and new H9 Control for Desktop V1.6.2! › Reply To: New TimeFactor V5.0.0beta[75] and new H9 Control for Desktop V1.6.2!
#138068
gkellum
    Beedoola:
    Cool, I was trying to use the H9 control with the TF via MIDI and it wasn't recognizing the TF. I used USB to the TF and all worked fine.
    H9 Control can connect to a TimeFactor through MIDI as well, but it doesn't scan all your MIDI ports for you testing if an Eventide device is connected to them.  When it launches, there's an option in the opening dialog with a button "Manually connect to device". You can use that to select the MIDI ports that your TimeFactor is connected to. After you do that once, H9 Control will remember to check that MIDI port next it starts to see if a TimeFactor is connected to it.
