Reply To: Bank and midi controller + levels problem
Home Forums Products Stompboxes Bank and midi controller + levels problem Reply To: Bank and midi controller + levels problem
#138107
LEONARDPAUL
Yes I understand that you can't help me with the GigRig2. But when I use a simple Midi controler such a Midi Moose from Tech21, the problem is the same with the Space but not with the 3 others (Time, Mod and Pitch).
When I don't use any Midi controler, there is a short delay between 2 presets. I try to change the spill but I only can choose On or Off. I tried each but it doesn't work 🙁
