Home Forums Products Stompboxes h9 not working on power up and weird message Reply To: h9 not working on power up and weird message
#138144
MrT
    Hi tone1963, Just wondering if you've delved into the midi section of the H9 in relation to the Ground Control… I'm trying to get the Ground Control to switch on the H9 (as well as load the preset sound) in just one hit, rather than going to my Commander to switch on the H9 then going to the Ground control for a H9 preset. I know there must be a way through midi mapping but can't figure it out!  at the moment I'm using any H9 algo turned off as my bypass switch, but that's effectively using up a preset.. Do you know what I mean? The Voodoo Lab Commander is great, you can switch pedals, Amps etc. but the Ground control at the moment is only changing H9 presets…
    Cheers 🙂
