Home Forums Products Stompboxes H9 Presets Share Reply To: H9 Presets Share
#138191
    Quote:
    Aside to ET: What happened to Dotted 1/4, 7/16, and 1/2 in the HarModulator?  In the last several versions of H9 Control, Delay A has the full range of time divisions.  Delay B maxes out at 1/2 Triplet. Full range using the PitchFactor hardware, but not reflected back to or from H9 Control.
    This GlidingDotted8th preset is a slightly tamer variation on the RubberBandGlitch settings above.  A perfect 4th quickly slides down to Unison, while the 5th glides upwards to an octave.
    The pitch shifts are spread against dotted 1/8 and 1/4 note delays.  I added a little Feedback here, but I usually program that parameter in the expression pedal for a range of 0 to 100.
