Home › Forums › Products › Stompboxes › Tap tempo with multiple H9’s? › Reply To: Tap tempo with multiple H9’s?
February 14, 2015 at 10:44 pm
#138267
Hey,
No luck with either option? Can I not have the core recognize the "ring" cable coming out on the "Y" cable? Also, tried MIDI cable, enabled H9 max MIDI clock output and Core MIDI clock input, attempting to have the H9 max be the master clock. The JHS is going into the H9 max as a tap tempo aux switch and works fine. Nothing happening on the Core in both scenarios.
