Home › Forums › Products › Rackmount › Strange behavior H8000FW with phaser presets › Reply To: Strange behavior H8000FW with phaser presets
#138279
Hi Nickrose,
Thanks for your quick answer. Most of the phaser effects in the 3510 – 3526 range are suffering from this problem (only the ones with a depth adjustment possibility). It is not exclusively limited to preset 3524 (I used that only as an example). Presets 3510, 3512, 3514, 3515, 3516, 3518, 3523, 3526 and 3921 all have this problem. Could it be possible that this whole range is affected with the same problem?
Regards,
Eric
