Home Forums Products Stompboxes WISH: Delay inside the Looper algo Reply To: WISH: Delay inside the Looper algo
#138295
Bodde
    Tried to be smart today and set the bypass to DSP + FX and programmed a Looper algo and Delay preset right after each other. So I could change presets and the delay would be fed in the looper with delay spillover. But I found out that unfortunately there is no delay spill over in the H9 when changing presets or algos, only 'bypass spill over'. It was worth a try though. Is there a technical reason that there is no delay spillover when changing presets? just curious….
