Home › Forums › Products › Stompboxes › Does v5.0.1 software have any problem with TimeFactor? › Reply To: Does v5.0.1 software have any problem with TimeFactor?
February 17, 2015 at 6:50 pm
#138302
Ok, thank you! It seems now I have some problem with the expression pedal (roland EV-5): it seems not always correctly changes the programmed parameters, nor it correctly shows the name/values. Also the flashing light indicating the programming mode, flashes when it's at 100% (toe down) but it doesn't when at 0 (heel down).
Possibly depending on v5 software?
