Home › Forums › Products › Stompboxes › H9 incoming tap tempo issue › Reply To: H9 incoming tap tempo issue
February 24, 2015 at 5:55 pm
#138360
Those are the only two choices when setting up the switch. One tap broadcasts 0, the next 127, the next 0 and so on. The switch isnt a latching switch. Isn't that they way it should work?
the H9 displays "learn" and I press the button it does nothing. It still shows learn and does not do anything else. I have to hit preset to go back up a menu level or right switch/hot knob back to play mode.
