Home Forums Products Stompboxes H9 incoming tap tempo issue Reply To: H9 incoming tap tempo issue
#138361
    I am assuming that you are trying to use the CC to tap in a tap tempo value, meaning you have a remote tap switch. If you are trying to use it to send a tempo value, you should study the comments from Mr Keys above. Otherwise…
    jaime136:
    One tap broadcasts 0, the next 127, the next 0
    This would not work as a tap switch – it needs to send 127 when you press and 0 when you release – much like a momentary pushbutton.
    jaime136:
    the H9 displays "learn" and I press the button it does nothing
    This rather suggests one of two things:
    1) That you are not sending on the MIDI channel the H9 is expecting. Set the H9 receive channel to OMNI to avoid this.
    2) that the H9 is not seeing the MIDI – check your cables and whatever is sending the MIDI.
