Home Forums Products Stompboxes Algorithm request for H9 Reply To: Algorithm request for H9
#138459
Per
    One more workflow request.
    When setting the pedals to sync, make the non-synced values correspond with the synced.
    Exampel: Use some kind of delay preset. Set the pedal to sync incoming signal of 120 bpm or just tap tempo of 120 bpm. Move the time divisions to 1/4 note. 1/4 = 500 ms in the tempo of 120 bpm. But when unsyncing the time division it shows something else. 254ms-293ms, on tape delay, depending on the knob.  Well whats the point of this? Its just an easy way to get synced, and then pull or push the time division a couple of ms for more groove. 🙂 Yes you can use some kind of time division table, but this is faster and more immediate.
