Home › Forums › Products › Vsig and Preset Development › Vsig on a Microsoft Surface? › Reply To: Vsig on a Microsoft Surface?
March 5, 2015 at 10:34 am
#138460
michaelbrook:
The Virtual Box looks intriguing, but potentially gnarly, as if one thing goes wrong I'd have no way to troubleshoot, and might screw up a Mac in the process.
You get it 😉 That is for shure .
Quote:
Does one have to buy WinXP, which I've seen on Ebay? Any particular version/flavor?
You can also work with Win 7 or 8 … there is a list out there.
I use the Usb-Serial Adapter from " Hama " .
You can also use the Midi Pin.
But in my case i can use both. The Visg Data going via VB Serial to the H8 while Logic sends Midi Data ( CC ) to H8 to the Mid socket . Simultaneously.
Good Luck
