Home › Forums › Products › Stompboxes › Midi Clock, sending tap tempo from Modfactor to Space › Reply To: Midi Clock, sending tap tempo from Modfactor to Space
March 22, 2015 at 5:16 pm
#138582
Not sure why you are sending the tip and ring – I would suggest you disable this. You might want to consider a "clear setup", and then just send clock from one unit and receive from the other, with not much else going on.
MIDIclock does not have a beat indication – it just sends tempo (quarter notes), so there is no reason why the lights would flash at the same instance in time.
