Home › Forums › Products › Stompboxes › H9 – controlling Midi CC from Musicomlab EFX MKIV › Reply To: H9 – controlling Midi CC from Musicomlab EFX MKIV
March 28, 2015 at 10:50 am
#138649
Also found out there is a preset 000 that I could use for tap tempo and other stuff.
It's not described clearly in the manual AFAIKT? When preset 1 (or any other preset) is active and you press the switch for the same number again the EFX MKIV goes to preset 000. To get out of this you still need to use enter/store and hold it.
