Home Forums Products Stompboxes H9 – controlling Midi CC from Musicomlab EFX MKIV Reply To: H9 – controlling Midi CC from Musicomlab EFX MKIV
#138650
So it's workable to use a preset, select it's IA2 and use FS1 to set tap tempo. Only thing that bothers me is that exit at that time would've been much easier to exit out of the instant access mode.
Only thing I haven't been able to make work is getting tap tempo to 2 H9's with only FS1 of the Musicomlab EFX MKIV.
Somehow the first H9 which has CLK OUT set doesn't send it's clock through to the other H9 when receiving the tap tempo CC from the Musicomlab, even when the output mode is set to XMT?
@Eventide: is that a potential bug? When CC Mapping is set the CC20 for Tap tempo on H9 #1 and it's output mode is set to XMT it doesn't send CLK OUT?
