Home Forums Products Stompboxes H9 – controlling Midi CC from Musicomlab EFX MKIV Reply To: H9 – controlling Midi CC from Musicomlab EFX MKIV
#138671
LA Keys
    harmamusic:
    That's probably an easier and cheaper solution then going the midi split/merge route.
    Agreed. That should be fine as long as you don't need midi clock for the Axe FX II…
    harmamusic:
    About this, I was trying to find an excellent previous post showing an alternate solution to Merge/Splitter using a single MidiSport 2×2 and finally found it.
    Here is the link:
    http://forum.eventide.com/cs/forums/t/7331.aspx?PageIndex=1
    I think you should gave it a look. It's anyways right along this topics and is an elegant solution to the "typical" midi clock problem. Note that the author made 2 graphics: one with the "conventional" spitter/merge way, the other with a single MIDISport 2×2. The later is to me a very clever way to solve the problem.
    LA
