Home Forums Products Rackmount Strange behavior H8000FW with phaser presets Reply To: Strange behavior H8000FW with phaser presets
#138726
Hi nickrose,
Do you have any updates about the phaser preset issues? I 've noticed by experimentation, that only the depth parameter adjustment is causing the "issues" in all the affected presets (except for the Modfactor presets). Is there any 'walk' around for this problem?
I also noticed that the bypass button settings (DSP-A, DSP-B) are not stored in memory after the unit is being switched off. Is there a menu setting to retain the bypass button status?
Eric
