Reply To: H9: issue with expression pedal (PC w/Bluetooth)
Home Forums Products Stompboxes H9: issue with expression pedal (PC w/Bluetooth) Reply To: H9: issue with expression pedal (PC w/Bluetooth)
#138740
LA Keys
KCStratman:
I posted a week or so ago that when using my H9s via blue tooth dongle to PC that the expression pedal arcs in H9 control were erratic, jumping up and down their range and would not stabilize to save new settings.
Well, I should say that I have a similar problem here. Same setup: PC -> bluetooth dongle -> H9
On my side if I move the endpoint on the Control software it takes forever to transmit the new "position" to the H9. I actually can see the endpoint sloooooowly reaching the new position on the H9 control software, although not jumping or anything…
It is as if the dongle was transmitting everery single intermediate positions to the H9. I'm a programmer and would like to suggest that there's many ways to solve this. Here is what I'm thinking:
Sending the new position after the mouse click (This is after the "up" of the click) would allow to send only the final position for this endpoint and largely contribute to reduce the data traffic send via bluetooth.
To alleviate this problem I'm simply waiting until the endpoint stabilize before touching anything else on the H9 software. This is also indicated by the bluetooth dongle stopping flashing. This is slow but a workaround this problem.
I also agree that indicating the endpoints with a disctinctive color would be a welcome improvement.
LA
