Home Forums Products Stompboxes H9: issue with expression pedal (PC w/Bluetooth) Reply To: H9: issue with expression pedal (PC w/Bluetooth)
#138747
ricklbrand
    Thanks for the quick response.  I guess that means an update is on the way?  I moved to the PC because of issues with my iPad Air and two H9s.  I'm really looking forward to getting this piece of the puzzle working correctly.
    Another, related question.  To turn off the expression pedal for a parameter, I assume the only/best method is to simply set the start and end of the light ring (arc) to be the same value?  Or, is there another method?  I messed up some of my presets trying to edit the ring and need to set them back to not being affected by the expression pedal.
