Home › Forums › Products › Stompboxes › H9: issue with expression pedal (PC w/Bluetooth) › Reply To: H9: issue with expression pedal (PC w/Bluetooth)
April 7, 2015 at 2:38 am
#138748
ricklbrand:
To turn off the expression pedal for a parameter, I assume the only/best method is to simply set the start and end of the light ring (arc) to be the same value?
The easiest way I've found is to double click on the control (virtual pot) and select "UnMap from expression pedal". This will get rid of the start and end points.
LA
