Home › Forums › Products › Stompboxes › Help,,,,, › Reply To: Help,,,,,
April 12, 2015 at 2:54 am
#138821
In H9 Control, click/hold and drag the heel and toe endpoints of the expression pedal range indicator arcs around any parameter knob. Check the action by click/hold dragging the lightning bolt to the left and right ends of the scale to make sure the desired knobs are sweeping forward or backwards. If needed, click/hold drag the endpoints back over each other to reverse the sweep direction.
