Home Forums Products Stompboxes Pitchfactor Harpeggiator’s output significantly louder than direct signal? Reply To: Pitchfactor Harpeggiator’s output significantly louder than direct signal?
#138831
gkellum
    spaceJam:
    Has the the Harpeggiator algorithm in the H9 the same issue?
    I've never heard of the Harpeggiator in the H9 having this problem, but even if it did, every preset has a preset output.  If you find a particular Harpeggiator preset to be too loud, you can always adjust its preset output gain.
