Home › Forums › Products › Stompboxes › USB Midi and Midi Din Cable In At The Same Time? › Reply To: USB Midi and Midi Din Cable In At The Same Time?
#138925
gkellum
    davec69:
    I have a Toshiba bluetooth program running in the system tray, and when I open it, I see my H9-09763, and it say's it is connected.
    Do you remember going through the pairing process and typing in your H9s pin?  If you didn't type in its PIN, I don't know in what sense it could be connected.  If I were you I'd try right clicking on it to disconnect it and then go through the add new device dialog to add it again.  But I can't guarantee that will help having never experienced this problem first hand.
