Home › Forums › Products › Stompboxes › 2 weeks and encoder button is down › Reply To: 2 weeks and encoder button is down
April 25, 2015 at 4:42 pm
#138941
Hi
Do you mind explaining what you did to fix the encoder button problem. I received an H9 Max yesterday and the encoder button does not work. It does not push in and when I turn it, none of the parameters change. Not sure if I should fix it or just return it
Thanks
O. Sroubek
