Home › Forums › Products › Stompboxes › H9 Wish List › Reply To: H9 Wish List
Here's an easy one (I hope). When using more than one H9, I like to use this arrangement of windows shown below. However, when you switch between more than one Device, the position of the Algorithm column resets to the top of the Algorithms list. For this to be more useful when working with more than one H9, having the app remember the position Algorithm strip for the each Device helps choosing between Algorithms when switching between each Device. Especially when you've got a MAX and the list of Algorithms is very long, you have to scroll through all the Algorithms each time you switch Devices. The same argument also applies to the column for Presets, but you don't into trouble as quickly as you do with Algorithms. Thank you!
