Home Forums Products Stompboxes M Audio Expression pedal doesn’t work Reply To: M Audio Expression pedal doesn’t work
#139108
LA Keys
    I’m thinking…
    If you can change the parameters from the H9 Control software you may also be able to use it to “program” your expression pedal.
    I suggest that you donload the H9 Control software manual and have a look at page 14. This does explain how to program the “light rings” for the knobs, thus how to set the range controlled by the expression pedal. This is probably much easier than setting this directly on the pedal.
    LA
