Home Forums Products Stompboxes Customer waiting until you… Reply To: Customer waiting until you…
#139120
Imerkat
    Fully aware of their rack units; bring it up is counter opposite to my post. Like is said change the form factor and the lack of new algorithms. H9 cannot be used to send MIDI CC though it’s none existing knobs. It does work as a standalone unit like the Factor pedals can (You can’t even use the hot switch without additional gear/pads). These are not delusional request (like having two algorithms at once) this is stuff their old units do.
    One of the most request features is Pre-Post routing. You have to know that impossible with the current form factor. There is also analogue dry-thru, which is a feature Eventide underestimates but I digress. Eventide has stated they are not done with the Factor format.
    Basically I would be thrilled if I could Max-out an Eventide SPACE…
