Reply To: midi controller
Home Forums Products Stompboxes midi controller Reply To: midi controller
#139159
LA Keys
“When I go to the Hp control app to set the midi the setting says none and there is no way to change it, as directed in the manual”
With the H9 control software, If you do to [pedal] -> [midi settings] -> [Program change receive map] you should see a drop down box that will allow you to load any presets.
If not make sure you don’t have both USB and midi connected at the same time. You should also see your stompbox listed in the left column of the app.
Also, if your preset is saved inactive it will be inactive when you recall it form a Program change. (Make sure you are sending  a Program change not a CC)
Omni or the same channel you use on the controller is fine. Midi thru is fine.
LA
