Home Forums Products Stompboxes midi controller Reply To: midi controller
#139160
LA Keys
    “Sometimes it seems to scramble the Time Factor settings although I set the H9 to not pass program parameters to the Time Factor.”
    If your H9 is set to midi thru and before the timefactor is should not send anything to the timefactor. It will just pass (thru) the command received from the controller.  This makes me think that your configuration is wrong on your controller.
    LA
