Home › Forums › Products › Stompboxes › Trying to get MXR-117 Flanger sound › Reply To: Trying to get MXR-117 Flanger sound
June 27, 2015 at 2:10 am
#139475
Here’s something to dial in. I took the settings from a “hard-wired” MXR flanger – all knobs at 12:00 o’clock.
Keep the SPEED between 0.10 Hz. and 10 Hz. to be accurate. MODFY DLY O/P isn’t calibrated in milliseconds, but between 0.5 and 16 ms. is the correct range. If you’re feeling experimental, you can use the Vintage or Mod Delay algorithms.
