Home › Forums › Products › Stompboxes › Power 12v or 9 v? › Reply To: Power 12v or 9 v?
June 28, 2015 at 9:00 pm
#139486
You need to be careful, these are not compatible with standard 9v power adapters, which are usually 2.1mm center negative. You need a special supply, I use a Voodoo lab Pedal power digiital, which comes with the correct adapters and amps required to run these pedals.,
