Home Forums Products Stompboxes Pre/Post Bypass Path Reply To: Pre/Post Bypass Path
#139719
May be the question was a little more deep, I will add one more question about the same matter:
1) when using the new PRE/POST feature a couple of IN/OUT jacks are bypassed while THE OTHER IS     WORKING allowing the signal to go through the effect. Which kind of bypass do we have here on the bypassed SIDE of the pedal? Digital, Relay or may related to the kind of “general” bypass mode chosen?
2) Same question about the new DRY/WET option: what kind of sognal flow through the DRY out?
To get an hard by-pass in those situation I guess it would require the H9 to have a twin indipendent bypass relay, one for each L/R side of the pedal… is this the case?
Thanks for your help.
