Home Forums Products Stompboxes Pre/Post Bypass Path Reply To: Pre/Post Bypass Path
#139731
    In the hope of answering the above questions:
    1) There is essentially only one bypass relay, so relay bypass will bypass both inputs, regardless of routing. Sorry – you will have to use DSP bypass in most cases to use Pre/Post or Wet/Dry.
    2) In both Pre/Post and Wet/Dry, the dry signal comes straight from the appropriate input(s) and is only digitized once.
